- Jun 20, 2022
- 206
I have occasionally had issues with my lathe tailstock drill chuck mt2 shank slipping. Not necessarily with oversized S&D bits (those too) but even with normal sized 3/8-1/2 bits. They are newish, sharp, CLE-LINE bits, and the belt on my lathe will slip if the lathe jams up hard. So I'm pretty sure there is a lack of lock up in the shank. Its a Logan 9b, there doesn't seem to be a tang slot, so it relies on the taper.
Thoughts on any easy corrections? Polish the shank? Ball hone the tailstock?
