Yeah, they're a tiny bit off to one side but all is well and I got lucky for two reasons... Both are off the same amount. Both are a little over-sized and when I mill them to correct size, I'll take a little more off on one side... (wheew... dodged a bullet on that one). Fortunately, it doesn't matter anyhow because the height of top shaft is controlled with two independent adjustment bolts... I think Father's Day luck was on my side today...
Ray
Ray, even your camera is a bit worn-out… the videos are undersized!
:roflmao:
Anyway thanks for sharing, they are nice!
Maybe I need a bigger lens installed on the iPhone... I do have a video camera that makes full-size images but it creates huge files that take a very long time to upload. The iPhone chops them down to manageable size and uploads them very quickly... I dread making videos really -so time consuming...
Ray
I think you should go back and get them both the same........
The crank handle on mine is 10" long View attachment 78862 View attachment 78863
You can see how much adjustment I have on my outfeed roller. View attachment 78864
And because the rollers are just in sloppy bushes you can crank 1 end more than the other to give you the "compound" curve View attachment 78865
I wouldnt even raise a sweat on your job, pretty sure I could wind a 3" radius on mine, but that would be about as tight as it would go I reckon.
Its not that strenuous to do. If you try to push it too hard it just gets too difficult to crank the handle. Just go back and forth adding a bit more pressure each time to tighten the curve.
Cheers Phil
I guess to keep the iPhone in "landscape mode" would solve the vertical issue
