- Jun 7, 2013
- 10,098
I quite agree with this post, best practice would be to use a spotting drill and then go to the full size drill; using small drills to start the hole invites wandering, the full size drill is much more rigid than all the other drills used.Could be a few things. What machine are you using? Some drill presses are not so sturdy and can flex.
You're also allowing errors to creep in by going up in small increments. Best practice is to have the pilot hole just big enough for the chisel point on the largest drill. When shaving off 1mm, particularly in ali, the larger drills are liable to grab and wander. In this case, 4mm then straight to 8mm should be pretty good
