- Apr 23, 2018
- 6,567
Nice cutter grinder. If you want to sell it, you will get your $400 for it readily. I use mine for end mills, taps, reamers, drill bits, lathe bits, counter sinks... Some angles need to be cut with a flared wheel like Stefan Gotteswinter points out... (speaking of whom, his great video on the Deckel clone leaves very little not covered). I have a few attachments to make grinding some of the common tools a little more practical. So while folks say they were designed for only sharpening rotary single flute bits, that is true, but it is not at all they are limited to. Thinking outside the box will give you more utility with it (use all 3 lips on your wheel to reach different angles, for example, or switch to a thin disk for flutes). I use the machine once for every two hours of machine work on average (not from breaking tools, but reaching for a dull cutter mid-process) so I'm keeping mine. Before I got it, the dull bits were piling up. Now I'll buy lots of cutters and bits on eBay not caring if they're dull or sharp, because I can actually do something about it!
