- May 27, 2016
- 3,469
Apparently, the term is discouraged. One should be saying "silver brazing" instead.
The aim is to get a very low electrical resistance joint on 22mm copper tubing that might carry high currents (200A).
The recommended stuff is something (probably tin) with 55% silver in it.
I understand that it melts at 650°C , which is 1202°F. That would be sort of reddish hot.
One hopes the butane can torch normally used for copper plumbing joints with tin/lead solder will get it there, but I can augment it with a butane gas ring if need be.
Is Borax OK to use as a flux? I have a tub of Borax.
