More or less rebuild kits for anything 20+ years old. Mostly Chinese junk. Have throttle plate bushings needing replacement , hard to find also.What for? Carbs? Depends on the type of carb if thats what you are referring to.
I entirely sympathize with your revulsion of the cost of repairs for this. Seems ludicrous.Here , looking at $2000 in parts from the dealer. A used seat with this climate crap….they wont warranty or even confirm the climate system works lolView attachment 488419
Seeing the thread is about the Sieg SC3 I thought that I could try and steer it back on track.
Anyways seeing that I'm using a ER40 collet chuck I would investigate a change of spindle to a 100mm one to go with my new bearings. Nothing doing in the UK and came across this one from the little machine shop.
Hope it's the right one as I've not stripped my machine down yet.
Here's hoping that this eliminates my annoying vibration. I'll let you know how I get on.
That's for the models without the hi/lo 'backgear', the models with brushless motors that use the belt to directly drive the spindle, rather than the belt going to a lay shaft.Seeing the thread is about the Sieg SC3 I thought that I could try and steer it back on track.
You can tell because you can see the longer keyway to hold the toothed pulley for direct drive from the motor and no keyway in the middle of the shaft for hi/low gears inside the headstock (which aren't there on the model that the spindle you've ordered is for).
If you've got a model without the hi/low gears then you're good to go. If not, you might want to see if you can cancel the order before it ships.
