I've use the oven many times to heat aluminum for projects. The nice thing about it is you can put it in for a fairly long period to heat all the way through where boiling it you have to suspend it in the water (if you leave it on the bottom of the pan, it gets hotter on the bottom than the top. But to each may be different. ALso I can do bigger parts in a standard oven than I can in a pot.
