- Dec 18, 2019
- 6,464
Umm, no, I want to shrink fit, by heating the aluminum and hopefully dropping the cold pin in place. Don't know if this will really work in practice without an arbor press, so I will make a couple practice tries before attempting the real pieces.You're not shrink fitting, you're force fitting. It should be no problem pressing your pins into a 0.002" undersized hole - even 0.003" should be doable. Heat shouldn't be required, but it can't hurt to heat up the Al bar before you press. Any press will do this with ease. I've even used a mill vice to do the pressing.
Other posters mentioned using arbor presses, which I do not have. As for using a vise, that will be a hard pass, as the last time I attempted using a vise as an arbor press, the cast iron nut in the vise broke into half a dozen pieces. And that nut was unobtanium. Nope, not using a vise as an arbor press again, learned that expensive lesson.
