- Feb 1, 2015
- 9,621
Wintertime heating consists of replacing heat lost to the environment. Heat loss is proportional to the difference in temperature so from an efficiency standpoint, lowering the temperature when you are absent will mean less makeup heat needed to replace that lost. I did this on my home in the 70's as we were gone working for 10 hours during the day and asleep for 7 hours at night. I lowered the temperature during that time to 45º, turning it up to 65º when we were there. I had installed a programmable thermostat so the heat would come on a half an hour before we got up in the morning and before we returned home in the evening. I recorded the furnace run time during on/off times and even including an hour for bringing the house up to temperature as part of the off time, I had a 50% savings in fuel.
However, in the shop, there is another reason for maintaining as constant a temperature as possible. If the room is cooled down during times when you're absent, the machines will come to at or near that lower temperature. When you raise the temperature, any moisture in the air can condense on the cold machines, potentially causing a rusting situation. This is less of a problem in winter because the relative humidity is lower then but it is something to be concerned about.
I try to keep the relative humidity in the house and shop at or below 50%. In winter, this isn't an issue since typical Wisconsin winters tend to be below freezing for highs. In the summer though, I run a dehumidifier from mid May until mid September.
