- Mar 26, 2014
- 1,495
It will only cost you dollars if you put it on your drawings. A 7/8” anchor has a pullout rating of 6000 pound and a shear strength of 13,000 pound. Think about putting 5”of 3000 MPs concrete with fibre mesh. This will support most anything you can put on it And also have greater strength for mechanical anchors.
Cheers
Martin
Technical Information: Ultimate Load Values in 2000 PSI Concrete
Values shown are average ultimate values and are offered only as a guide and are not guaranteed. A safety factor of 4:1 or 25% is generally accepted as a safe working load. Reference should be made to applicable codes for the specific working ratio.
Cheers
Martin
Size | Minimum Embedment | Drill Bit | Pull-Out (lbs.) | Shear (lbs.) |
1/4” | 1-1/8” | 1/4” | 877 | 1082 |
5/16” | 1-1/8” | 5/16” | 892 | 1156 |
3/8” | 1-1/2” | 3/8” | 1223 | 3238 |
1/2” | 2-1/4” | 1/2” | 2999 | 5564 |
5/8” | 2-3/4” | 5/8” | 3749 | 6198 |
3/4” | 3-1/4” | 3/4” | 4978 | 9378 |
7/8” | 3-7/8” | 7/8” | 6294 | 13687 |
1” | 4-1/2” | 1” | 7329 | 17712 |
1-1/4” | 5-1/2” | 1-1/4” | 13162 | 24206 |
