- Sep 22, 2010
- 898
BK
The issue with these motors is when you need to crawl with them, they have little or no low speed torque. At higher speeds they are definitely OK.
I wanted to get my scroll saw 924" Beaver that I am sure was used by Noah to build the ark) down so that I could really control the strokes, especially when sanding carbon with it. These motors could not get low enough to get the blade even moving, unless I was at speeds that were already available using the conventional motor and belt changes.
For an application like your mill, where you are turning at a decent RPM and not starting under a heavy load they will work fine, I am sure.
Walter
Walter
