- Aug 29, 2019
- 584
I will be doing only one side of the VEE at a time. I do not plan to machine either the Vee or Flat Way to what would need to be done if I was replacing with Turcite. This is the beauty of using Moglice. It forms to what ever void it is in. I will be sure to document as much of my project as I can as I go along.Those are sure weird! That straight section next to the V way really complicates things!
Is your cutter long enough for the full width, or are you going to have to trig your way down?
You may need to grind the end flat. The surface speed will go to zero on the point.
Sent from my SM-S911U using Tapatalk
