- May 4, 2013
- 249
you can add a delay on break relay till you get past first bump..
you other guys can verify this..i'm half asleep but i think i got it right..lol
also depending on how fast it is turning you may need a wider lobe
I think what you are referring to as a "delay on break" relay is commonly known as a timer relay. This could certainly be an option, though adjustment for more spirals will be a trial and error process.
The beauty of the latch circuit is that even if the lobe does not stop with the switch still struck, the circuit is broken, and the motor will come to a stop. That is unless the foot pedal is depressed. The only quirk is that if the foot pedal must be held long enough for the lobe to move off of the switch for the first revolution. Otherwise the circuit will break as soon as the pedal is released. In this regard, the lobe could be very small, enough so that the motor will coast past it upon stopping. This way a quick tap of the pedal will start the motor.
-Cody
