- Jul 16, 2013
- 16
The plan was to use a band clamp around the yellow part . The band clamp would have a bump on it to activate a micro switch . By using the clamp it would be easy to time were it stopped by sliding the clamp around .
All was well until it dawned on me that the scrolls will be more than 360 degrees . The plan that went south was to use a foot switch going to a mag start with a hold circuit to a drum switch to reverse the motor . Is there any way to hold the foot petal down until the micro switch passes the first time then remove my foot allowing the hold circuit to hold until the micro switch stops it ?? Thanks Dommy i mean Donny:thinking::thinking: P.S . I thought i might add the scrolls i am bending are out of 3/4 solid round bar and i have a boat load of then to bend . The bender has the power to bend the bar stock 180 degrees around a 3/4 pin making a large hair pin. Having the capability of stopping the rotation at the same place will speed production and improve consist scroll shape
