Speaking of electrical safety and Canada, you guys don’t use wire nuts?
What/how do you join electrical wires in a residential/commercial building?
I am an "old school" electrician, and set(50+yrs) in my ways. Always remember any code is
not a standard, it is the
minimum acceptable. When using wire nuts, the wire nut is the insulation cap over a joint. The wires must hold themselves together alone, twisted is the usual technique. Stranded wire is altogether different from solid in the way it is twisted.
Solid wires are twisted together in a pigtail splice, right hand tightly, then trimmed and a wire nut screwed on. But, what about wiring a light fixture?!?! An AWG 12 solid to an AWG18 stranded. The fixture splice must be used, with a wire nut to finish it off. There are many situations where a wire nut simply won't work. And that's
before "industrial" comes into the question.
Most books and videos show a wire nut being used simply by pulling the wires together like your fingers and screwing on the wire nut. They are full of BULL$#!%. Such a splice
can fall apart the first time it is touched or moved. The splice
must hold itself together first with a wire nut as a cap.
I use wire nuts inside in conduit or boxes for residential work. Outside, I use Kearneys(split bolts) and tape. And never a crimped connector, the only place that is crimped at my house is the gooseneck above the power meter. But that doesn't belong to me. I offered kearneys but they were declined.
As far as safety glasses, I must stress that my mother was blind from childhood. I grew up thinking that some people could see and some couldn't. I have seen people that were blinded as adults. Their attitudes toward life scared me so much, I was using safety glasses before I started school.
At 70ish, having all my fingers and toes and both eyes says all that needs to be said. I worked in a pipe foundry before OSHA had any teeth. We wore sneakers and baseball caps on the casting floor. Safety is not a matter of how much equipment you can hang on the body. It's in your mind, being aware of what is going on around you and avoiding any dangerous mis-step.
