Thank you, I appreciate your input. That’s what I don’t want to do is buy twice. I’m a buy once cry once kind of guy. Been scoping fleabay out, there’s a few that grabbed my attention but I figured I better get some info from you guys first. Thanks6"-8" are a good fit for the mill/drills. Brands come down to what you can find, but I consider the Taiwan-made Vertex as the floor for acceptability in quality and motion. Older Japanese RTs are very nice. There aren't many US makes in that size range. There are a lot of Chinese ones out there, but they are meant to look like a rotary table more so than function like one. I don't think I'm alone in that opinion, and I'm warning you so you don't have to buy a tool twice to find one that you like using.
Just curious, what's "too large" mean? Too heavy to lift? Or does the footprint of the thing prevent access to other functions on the mill?I have a no name, made in Japan, 10" Rotary Table and it's sort of too large for my Bridgeport clone, 9"x42" table.
My RT is probably from the 50's 60's, so built very solid and yes, quite heavy. It is slightly wider than the mill table, and requires moving the vise to mount it. A smaller one would fit next to the vise and be more convenient to use. It's also a horizontal style, I would probably make better use of a horizontal/vertical model.Just curious, what's "too large" mean? Too heavy to lift? Or does the footprint of the thing prevent access to other functions on the mill?
I have a 9", but my benchtop mill is a lot smaller than your BP so maybe similar proportionally. Compared to a 6", I'm glad I have more room for clamps, without needing a separate adapter plate that overhangs past the turntable. I like the size.
In general though I like the idea of buying one that's big enough for most jobs and no bigger, if only for lifting it, and storing it when it's off the mill.
Mine is a Troyke, made in Ohio in the '40s, very high quality and cheaper than a new Chinese one. Of course buying used comes with risks like worn-out surfaces, broken or missing parts etc. I lucked out, mine was rusty but apparently little used, "low miles", cleaned up nice.
