- Dec 18, 2022
- 1,722
I wanted one with the handle but I had a project I needed it for so I settled for this one. I have found that I move it close to what I need snug the bolts and tap it with my orange dead till it is where I need it then tighten. Surprisingly the one I have is fit together so nicely that when I tighten it I rarely see it pull off any.With the location of the slots on the mill the crank bumped into the table and caused issues, it did work the tilt nicely though. I still have the parts.
Edit - sometimes the closeness of the tee slot nut slots and the clamp the angle nuts is quite tight, only annoying thing about it for me
I made some small clamps for it also as everything I had was to big.
Common issue I bump into , is that Tee slot the same size as anything else I have ? yeaahhhh naaaaa
Stu
