- Jan 28, 2022
- 847
Hi, just would like to show my table feed unit using a mill table feed for rotating my r/t. My first idea was a belt driven affair that worked but in order to reverse the rotation I had to twist the belt into a figure 8 as shown in the pictures. Above all I knew I was placing a hard side load on the worm gear bushing of the r/t. The latter pictures are my latest attempt. It works nicely and has a wider speed range. I had to rotate the feed 90 to clear the table knee. Now when I clean up 18"x1/2" diameter plates the finish cut is clean. Thanks for looking, Charlie.
