- Apr 29, 2019
- 2,063
That is why I mentioned using the car as a winch. If the car has a hitch that is perfect. Run the cable under the car and attach it to the rear of the car so that the driver is moving forward while lowering and can see what is happening.
A car and a length of steel rope with stuff to terminate the ends (at least 1/4 Dia) from the hardware store, and some plywood (maybe a few 2x boards for the stairs) is all that is needed. I had 4 people, not big strong people. One driving the car to lower or raise the load. one at the top of the stairs to relay info to the driver, and 2 to guide the machine down the ramp from ABOVE the machine. Depending on your setup you may not need the one at the top of the stairs, especially if you have some walkie talkies. One person should be plenty to guide the machine down, 2 is just safer as long as there is room for 2.
IF the cable will hit the top of the steps as you are going down, you need to place a board there (board must be secured so it does not slide out of position) for the cable to slide on so it is not damaged by the corner of the top step. I used my engine hoist with a pulley for this since I had to run the cable thru the house and out a window that lined up with the stairs and I had to hold the cable up off the window sill, and high enough to not hit the top of the stairs.
If I were closer I would love to come help play with new toys.
