- Dec 18, 2013
- 2,012
This is an assembled in USA Rolair 20 gallon compressor 1.5 HP 7.3 CFM model 5520K17A. If I had to sum up my review I would say its 'buyers remorse'
First while they assemble them in the USA I guess they don't test them because the thing has a ridiculously bad air leak at the drain valve on the bottom of the tank. It lost 10 lbs pressure in just a few minutes and was completely empty the next morning. Its a little plastic knobbed ball valve from the looks of things, I don't know maybe I can replace it with a Home Depot ball valve that actually works.
My second regret is its LOUD. I was seeing decibel ratings of 70 to 80 for other Rolair compressors but could not find a rating for this particular model. My guess is because its freaking 95 decibels. That's as loud as a 5hp table saw or a 2hp cyclone dust collector at full tilt. The model I liked was the 20 gallon upright for $450 less but it was made in China, its only 80 decibels, I guess I should have gone that route.
