- Nov 24, 2014
- 3,179
The pin is a clevis pin, with a head on it, right?
How is the pin retained (before it rusted in)?
I doubt that the pin is very hard. I would try warming everything up with a torch then douse with penetrating oil and let it sit for an hour or so.
Perform multiple cycles, maybe 10 over a couple of days. Concurrently, try drilling and tapping the pin, 3/8-24 if you can. Thread a stud into the pin. place a short length of tube or pipe over the head of the pin/stud. Use a nut on the stud (over a plate with hole) to draw the pin out.
The pin may loosen during the drilling and tapping process if you get a few heat/oil cycles on it.
To your original question: the hole grows more than the pin (for parts with the same CTE).
PS: Your OP did not describe the actual circumstances well.
