- Feb 1, 2015
- 9,645
I would go with the JB Weld or similar metal filled epoxy approach.
Like said above, I would just fill it with JB Weld or similar. You could pound a plug in if you like first, but I doubt it would matter.
I would be happy with JB Weld. If you're not comfortable with that, you could fill the void with plumbing solder, lead, babbitt or any other low temp metal.
YES THIS IS BEST SOLUTION262100102 | Brownells
Brownells is your source for 262100102 at Brownells parts and accessories. Shop our vast selection and save!shop.brownells.com
No. The original 'bearing' was the casting surface. I have machined a low carbon steel busing. The lathe feed rod should have sufficient oil. The feed rod to bushing is a loose fit and very low rpm.@dansawyer
After filling the void, do you still plan to install Oilite type bearings to carry the shaft?
Is the advice to make a 'dam' and simply fill the gap from the top? That would be bog simple compared to trying to machine a slug.YES THIS IS BEST SOLUTION
