- Jun 12, 2014
- 4,816
One thing to be very careful about if you are planning to go to a 2 stage compressor/175 PSI is that many regulators and air filters have maximum pressure ratings that may be exceeded. Any filter with a polycarbonate bowl typically have a maximum pressure rating of 150 PSI. Above this pressure they are metal bowels (you should not be able to see into the bowl). I have been using the Norgren filters and regulators on two compressors that I have, they have worked very well. I bought mine as NOS on eBay at about 30% of the retail cost. I have the previous series which are the F74/B74 series with a separate particle/water F74G filter followed by a coalescing F74C and then a regulator. Newer series is the F84/B84 . I use the 1/2" port series and the connecting pipes is 3/4" to limit pressure/flow drop. I tun the compressor regulator to 130 PSI and then have separate air regulators at each drop. I run a 2 stage compressor ~15 CFM@175 PSI. If you get a replacement compressor consider getting an inter-cooler which drops a lot of the moisture out of the system, I get no water in any of my drops.
Norgren B84G-4AK-AD3-RMG Filter Regulator 1/2" with Knob, they also come in 3/8".
Norgren B84G-4AK-AD3-RMG Filter Regulator 1/2" with Knob | eBay
<p>This filter regulator from Norgren is a reliable and high-quality product, perfect for those in need of compressed air treatment. With a port diameter of 1/2 inch and a unit quantity of 1, it's suitable for a wide range of applications. The brand is well-known for producing top-notch...
www.ebay.com
