- Apr 2, 2024
- 3
Hi, first post here, I looked at some of the past posts from many years ago that confirm my thoughts but still thought I would explain my situation and see what ideas come up. I have a really clean 1930s South Bend 9 inch lathe. Its a dandy other than the first couple feet or so of threads on the keyed lead screw that runs parallel to the bed is worn out. I was originally just going to turn it a half round and mill a new slot on the other side to get rid of the worn slot but the thread themselves are pretty much pointed and sharp next to the head. I just spent all afternoon searching the net for replacements without much luck, for $22 a foot I can buy the threaded shaft so then I would have to mill a slot in it and probably cut the ends off the original and weld on the new all threaded shaft. My other option would be to put the new slot in the worn out threaded section and cut off the two ends and reverse it. Of course instead of having 7 ft of threaded lead screw I would only have 4 or so of usable so that seems like a lot of work to build a shorter lathe. I have picked up several old lathes and they all got the same problem. I already replaced the half nuts and that did take out part of the slop but I would really like one nice lathe to work with. Thanks for any ideas or suggestions, maybe I am not thinking of something obvious? If there is any place that specializes in South Bend Lathe long lead screws please advise, I find cross feed ones all over the net but not any long ones specific for this need.
Thanks, Aaron
Thanks, Aaron
