My machinist has phoned to say that the table is bent!!!! It rocks on the saddle and he can't take a straight measurement. It seems that I have big problems. He was originally going to grind and then 'Turcite' it back to original size. However, he can't determine which end to use to straighten the table. Ultimately, there's no problem straightening the table, but the problem lies with re-aligning the table feed screw in the saddle. He thinks it could need grinding as much as .043" in places.
He has suggested that I may need to have the table feed screw casting ground off and machine a new one. Also there may be an option of boring out the centre of the table feed screw casting. I would then need to make an insert to the original internal diameter, but off set in the bore by the amount taken off the table to realign it.
I'm off to see him today to get a better understanding of the problem.
