Hi all, I'm building a Reil burner for a small foundry and it calls for the end of the burner tube to flair at 1:12. I plan to drill out and then bore the taper with a boring bar in my 9A South Bend. Trouble is, the markings on the compound are in degrees and I'm at a loss on how to do the math.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Extra question: This isn't something I need to know for a project but I've always wondered about if you had a pentagon 5 sided or a 7 sided rod, but only a 3 and 4-jaw chuck, how you would hold it. If the rod were long and it needed to go thru a steady rest, how would that work.
There must be a better way to hold it (other than driving between centers) with the chuck and steady. My guess is for the steady, mill out a sleeve that's round on the outside and same for the chuck.
Thanks
Thanks
