Thanks brino, our bender is made by Pro Tools, https://pro-tools.com. When we built our shop we embedded a 12" X 1" steel plate in the floor. Four 1/2" bolts attach the bender and we use shims to level it up. We store the bender in a corner of the shop and plug the bolt holes with set screws when not in use. It only takes about 5 minuits to set it up, but it's heavy and it takes two people . I think using a reciever hitch would work fine but you would need some way to fine tune the level. If you do buy a bender be advised: You will ruin a lot of tubing before you get it entirely figured out. As to the power plants, we are the second largest coal fired generating plants west of the Mississippi, and one of the cleanest.
