- Feb 1, 2015
- 9,645
The DIA/RAD function can be toggled at any time. If your zero is set at the spindle axis, the displayed values will reflect the actual diameter or radius. On my TouchDRO, the function only applies to the x axis although it may be possible to enable it for other axes in the Settings menu. My TouchDRO is several years old and the functions may be different on newer versions. The answer man is Yuriy (@ycroosh) as he is the designer/of the TouchDRO.I hadn’t thought about needing to turn diameter mode off on a non diameter. Hopefully I can apply diameter mode to a single axis and not others in TouchDRO. I would think so if it’s use on lathes much. Needing to remember to turn it off would probably make me not want to use the mode.
