- May 3, 2017
- 1,997
Whoa!!! I didn't know that! Been charging mine in and around studded walls for years, but that looks scary. What would you think about a piece of 16 or 18 gauge sheet metal behind it with 6" or so sides above below and on the sides? Kinda like a box hanging on its side with no lid?I have some rectangular aluminum tube 2" x 6" ...hmmmm
By the way, I personally would not charge Li batteries on or around a wood surface. For my ebike batteries they recommend only charging outdoors or in an ammo container or oven. I may build a dedicated charging station that is fireproof.
To wit- Samsung S7:
R
Also, I actually thought about making mine out of 1/4" plate aluminum that I've got lying around, but I had one problem: I STINK at TIG welding. Made a good pass or two on steel, but all I've ever managed to do on aluminum is melt it into glob. Someday, I'll come up with a project to practice on, but those tight inside corners were unquestionably beyond my skill level. I would think aluminum tubing would be great because of the rounded corners. If you try it, I'd love to see some pictures.
Regards,
Terry
