- Oct 26, 2023
- 82
My four way using 1/2" shank carbide insert cutters the hight is perfect without shims. I rarely use smaller cutters but now with the help of some great tips I have options. I milled up some 1/8" shims and glued them to the bottom of the 3/8" cutters I have and the hight was perfect. No more fiddling with shims.It amazes me the amount of knowledge that's available on this forum!!If use four way you need shims to adjust the tool height.
The the weg type to fit mini lathes { OXA}.
If use a Aloris you need to adjust the compound hight or buy a slide from LMS.
I had a Aloris and put on my mini lathe by buying a new lower compound.
Dave
