- Oct 15, 2013
- 300
With the warmer weather I can finally think about getting my TH54 up & running. I noticed when turning the chuck by hand there seems to be a noticeable drag whenever the lead screw reaches a certain rotation. I wonder if a gear/gears got crusted with dirt on the top side as it sat idle for many years(?). Also the two selector levers seem to be quite loose at their bases (is that common?). It works best to use two hands to move the levers side-side. So I'm thinking a disassembly is in order, to check things out.. I have the manual for the gearbox, but is there anything special to watch for when taking it off/apart? Is it timed to the spindle or drive gears in any special way? :thinking:
PS: A little surprise for me, I discovered this one has a power cross feed! I wasn't even aware my lathe had that. :allgood:
