Please forgive a stupid question but how does this work? It would seem to me the right way to do it would involve an e-stop switch. I am obviously needing to learn more on this because I need one too.
The reason for my stupid question arose from me threading an 8 tpi internal thread the other day. Even in back gear at 50 rpm with a low thread count the carriage moves quickly and you have to be very quick on the halfnut to avoid hitting something. I guess this stop was not intended to address that situation.
It would seem that it wouldn't be too hard to design an adjustable stop with an e-stop switch mounted on a spring loaded probe that allows enough travel to adequately stop the lathe in back gear. Has anyone ever heard of something like this or done it themselves?
an e-stop can be included in a carriage stop, but obviously it will be a bit more complex as it needs to shut off and brake the spindle/gears immediately.
That said - for threading control you can do one of the following to avoid running into a shoulder:
1. cut a relief cut at the end of the threaded part so you don't have to thread all the way to the shoulder
2. thread from left to right (carriage moves from headstock to tailstock) - that way you start at the shoulder, and never have to worry about hitting anything. keep in mind to stay with a LH or RH thread you would need to position the cutter accordingly when moving in "reverse"
