- Sep 28, 2013
- 4,319
The parts manual describes the pin through the right eccentric and shaft as a "roll pin". I never heard of one that was tapered.
On another but related subject, the parts manual does not show a roll pin in the left eccentric. Nor any other way of securing it to the shaft. Does it also have a roll pin in it?
You're right, it's a roll pin and not a tapered pin, but it was definitely happier coming out one way than another on both the ones I've taken apart. Probably a consequence of being whaled on by a previous OP with a hammer and punch I'd guess.
From memory, the left eccentric is pinned in place, but a tight interference fit that would make removal a very committed process
Standing in the operator's position on the right hand end of the back gear shaft is the little shiny lever that controls the cam. I don't see a roll pin but there is a nub of metal on the rim of the metal and another spot for a set screw (which is missing). I see part of the detent BB if I look for it.
Update: I just went to Dean's photographica. Is it truly a roll pin (the hollow piece with the slit down the length of the side) or could it be a solid pin? I do see something that looks like a solid pin that may be in the right position. I'll bet that's it.
It was probably originally a roll pin as Bob noted above, but who knows what's been stuck in there over the 60-70yrs since it was made! I'll bet that pin like thing is what you're after. I didn't have a pin punch that size so I think I used a fine thread cap head screw the right size and gently tapped it out. I know I know, not exactly the right tool for the job but it worked and I didn't damage anything
