- Dec 25, 2011
- 10,508
Dan,
Unfortunately, Sears never had Atlas do an exploded view drawing of the 101.07301. However, for most of it you can use the manual for the 618 or 101.21400, several different versions of which do have Illustrated Parts Lists. Whats different are the headstock, spindle and the countershaft assembly.
The headstock is pretty obvious.
What's different on the spindle are the bearings (they go in the same location and you have no dust covers to worry with) and a thrust bearing and spacer on yours versus a collar on the 618. The pulley bushing part numbers are slightly different because the spindle diameters are slightly different, but they are in the same location. Once you have it back together, bearing and spindle end float instructions are in most of the Operation & Parts manuals.
On the countershaft assembly, the main brackets (that bolt to the table) are slightly different (the bracket on most 618's is the third version but for some reason the on on the 101.07301 always remained at the second version). The hanger assembly (carries the two pulleys) is the same. How it mounts to the bracket is different. On yours, it sticks up from the bracket. On the later 618 it hangs down.
Everything else is the same except that on the 101.07301 the motor is generally shown as sticking out to the left of the headstock and on the 618 or 101.21400 it is behind the countershaft assembly..
If anyone with a 101.07301 wants to add to this, feel free.
