- Jun 20, 2022
- 235
Not sure if this is clear, threaded collar, 4.6 inch hub, bolted to chuck with 6 cap screws. Want to take this off, true it, bore hole for hub in center of back plate I buy, true the new plate, turn boss and mount to new chuck.
I did exactly what you are talking about with the stub adapter that came off an old Skinner 4 jaw I got ripped off on (Ebay). I just used a big enough piece of 3/8 hot rolled to adapt the stub to the new chuck, but certainly cast iron would be better. I bored a tight fitting socket in the adapter plate, and drilled it for cap screws. I have it on a 4" 4 jaw so i only use it for small diameter work, but it sure seems perfectly solid.
Hopefully CME has some quality controls on Sanou. The Chinese 6" chuck I got from Shars seems ok. The 4" Sanou referenced above only has 1 of 4 jaws that fit right in their slot. 1 is too loose and 2 are really tight.
