- Jun 23, 2011
- 786
Sorry John, I guess that explanation was in another thread. Here it is:
"Back rake is over rated for high speed tooling and generally unnecessary. I grind all of my tools with zero degrees back rake, use them in a quick change tool post and they cut just fine. About the only time I'll ever use back rake is if I'm machining something soft like wood or rubber or some plastics. Back rake when cutting steel is actually a bad idea because it removes material behind the cutting edge of the tool which allows heat build up. Another plus for tools with zero back rake is you'll get a lot more life out of them since the tool geometry doesn't change as the tool is sharpened."
Tom
Thanks Tom,
That's something new for me to play with. I generally like cutting tools with LOTS of back rake: like with a tangential or the net result of having a chipbreaker. Since grinding the back rake for me is usually a freehand operation (whereas the relief angles are set by my toolrest), it could eliminate a step... Also, since the top of a HSS blank is ground very smooth, I would guess you could, in theory, end up with a better finish with just a light honing of the cutting edge to get rid of the coarse grinding marks.
I'm not sure I understand what you mean by "removes material behind the cutting edge of the tool". As far as I can tell, the cutting edge still does all the work and the back rake just presents a steeper angle to the workpiece for chip control. Can you explain?
Thanks,
John
