T
Tom Griffin
Forum Guest
Register Today
I certainly don't want to start a fight, but the cutter is flat because both Bill Gruby and tomg recommended that I try it that way (unless I misunderstood them, in which case, my bad.) I'll put a little rake on it, and try again in the morning!
Mike,
You misunderstood...probably because I didn't explain it very well. :thinking:
Here is a pretty good diagram and chart from DiscoverLiveSteam.com showing the various angles for different materials:
Sharpening Lathe Tool Bits
Just ignore all references to back rake because as I said before, it isn't needed. What your tool lacks is side and end cutting edge angles and side rake. Everything else look pretty good.
Tom
