Was this pun itended...........?Interesting thread for me...
I totally missed it...Was this pun itended...........?
hman said:**PS - I'm wondering if Cleeve might have been referring to producing gears with prime tooth counts(?) Despite having a goodly number of rows of holes on the dividing plates, my own rotary table is incapable of producing any prime number gears from 67 on up. It can produce prime interval numbers (gears or whatever) with values between 2 and 61, because the index plates include all these numbers or multiples thereof. And yes, you can produce pseudo-prime gears by cheating a little bit. For instance, I figured out that if absolutely necessary, I could probably produce an acceptable 127 tooth gear. (use the 62 hole plate, advance 44 holes for 15 teeth, then 43 holes for the 16th tooth. Rinse and repeat until done. Maximum error 0.065º)
They had AOL in those days????Easier and more accurate, make a temporary 127 hole plate (cad or excel piechart), glue to an unwanted AOL CD-ROM and step around worm-ratio hole spaces (or line spaces) to make a first attempt, use that to make another, rinse and repeat, each iteration will be more accurate by the worm ratio so assume a 2* initial error and 90:1 the first try will be out by 2/90*, second 2/8100*, 3rd by 2/729000* - how the first generation were made, way back!
Dave H. (the other one)
No problem ... mainly curiosity on my part. Best wishes dealing with the dadgum gummint bureaucracy!I will, John, but not now. I just spent most of the day trying to get a building permit done so I can finish a shop extension and get a slab done. My lathe is pushed in a corner and I have no idea where my Cleve book is so this will go on the shelf. I cannot believe the BS involved in dealing with the City. Sorry, but I am in no mood for this right now.
