- Jan 2, 2014
- 8,852
Can edm be manually controlled? Btw
An interesting question. Normally EDM requires small precise movements. However, I wonder if you couldn't use a small electrode manually. The process would be somewhat like striking an arc with sick or TIG welding. A TIG tungsten in an insulted holder could be used to peck away at the corners of your hole. A chisel shaped electrode could be used as well to "carve" a flat wall. An interesting experiment I'll have to try.
Maybe some of the forum members who have dabbled with DIY EDM machines could comment?
I have dabbled with home-brew EDM, here and here.
My take: The EDM metal removal rate is very small (at least with my DIY rigs).
You would need to hold your electrode very stable for many minutes to hours.
Plus with the deluge of water (or other fluid) your visibility would be greatly impaired.
If you were to produce the bulk of the hole by other means, you could still finish with EDM for better corners, but I think you'd still want the electrode held and fed by machine.
-brino
