- Nov 25, 2015
- 8,399
whenever molding you need to consider the draft to remove the part. Also you never mold over a rough part. You need to sand it and finish it with a smooth finish, leaving a rough finish is giving tooth so it won't come off. you have 2 straight sections with no draft... Soaping water would have been the last thing I would have done. Water expands the wood making it worse. I would have drilled the center with a large drill , if that didn't help, then tried to cut two split lines 180 degrees apart, or 4 if you couldn't release it. That should have helped.
