- Mar 8, 2017
- 87
So I went to lubricate my machine and half of the ball oilers are pushed in a 1/4" or more and I'm not able to lube theses points. Anyone have recommendations on replacing theses?
Find a screw to jam in the hole (fine thread, parallel sides, flat smooth end; forceSo I went to lubricate my machine and half of the ball oilers are pushed in a 1/4" or more and I'm not able to lube theses points. Anyone have recommendations on replacing theses?
How do you like the Miata? I'm thinking of getting rid of my mustang for something more economical.I contacted Matt and he sent several replacements. You can always just replace the bad ones with new higher quality ones and be done with it.
Thanks PM, I will make the McMasters units work unless the ones you have are built with a shoulder on them, if they do I would like to use them.If you need some, I have a whole box. If you find some others let me know, never found any that will fit from mcmaster.
