    Dismiss Notice
PM727 ball oilers suck
Discussion in 'PRECISION-MATTHEWS' started by Livnpaintball, Jul 15, 2017.
  1. Livnpaintball
    Livnpaintball United States Iron Registered Member
    7
    3
    City:
    Dfw
    State:
    Texas
    -Return to Top-
    So I went to lubricate my machine and half of the ball oilers are pushed in a 1/4" or more and I'm not able to lube theses points. Anyone have recommendations on replacing theses?
  2. The Liberal Arts Garage
    The Liberal Arts Garage United States Active User H-M Supporter-Premium
    110
    43
    City:
    Keene
    State:
    New Hampshire
    -Return to Top-
    Find a screw to jam in the hole (fine thread, parallel sides, flat smooth end; force
    Into hole , gently pry squarely . Don't lose ball, spring.. Clean with pipe cleaner,
    Etc. Re - shape retainer over suitable pin punch. Be gentle, she said. .....BLJHB. P.S
    GET AN EAGLE OILER.
  3. jer
    jer Active Member Active Member
    51
    28
    City:
    SE
    State:
    Colorado
    -Return to Top-
    I contacted Matt and he sent several replacements. You can always just replace the bad ones with new higher quality ones and be done with it.
  4. Livnpaintball
    7
    3
    City:
    Dfw
    State:
    Texas
    -Return to Top-
    I ordered some from McMaster Carr, much better than these little crap metal plugs they put in our machines.
  5. Livnpaintball
    7
    3
    City:
    Dfw
    State:
    Texas
    -Return to Top-
    How do you like the Miata? I'm thinking of getting rid of my mustang for something more economical.
  6. jer
    51
    28
    City:
    SE
    State:
    Colorado
    -Return to Top-
    I bought it 12 years ago. I really liked it but it was under powered. Over the years I have replaced the engine, suspension and most everything else. I turboed it and had a prepped engine built for the track. It is very fun to drive now, with my street tune it has 285HP and 275LBS torque, @ only 14 LB boost, on the dyno. It doesn't lack for power anymore. Oh, about economical, I get over 30 MPG still on the road. track mileage, not so much.
  7. qualitymachinetools
    qualitymachinetools United States Active User H-M Supporter-Premium
    253
    63
    Pittsburgh, PA
    City:
    Pittsburgh
    State:
    Pennsylvania
    -Return to Top-
    If you need some, I have a whole box. If you find some others let me know, never found any that will fit from mcmaster.
  8. Livnpaintball
    7
    3
    City:
    Dfw
    State:
    Texas
    -Return to Top-
    Thanks PM, I will make the McMasters units work unless the ones you have are built with a shoulder on them, if they do I would like to use them.
  9. coffmajt
    coffmajt H-M Supporter - Premium Content H-M Supporter-Premium
    113
    43
    City:
    Oklahoma City
    State:
    Oklahoma
    -Return to Top-
    I replaced several of these with "zerk" fittings so that I could use a better push type oiler on the ways. Works so much better. Jack
Share This Page
