- Jun 12, 2014
- 4,817
Not really and issue since the resistor's I recommend are completely sealed and the wiring is embedded. You could also mount it on the inside of the VFD cabinet which I have seen done. It does not get warm so heat is not an issue. My original 1340GT VFD with the WJ200 had it in the headstock cabinet with the braking resistor mounted to the side, but I quickly went away from that to a separate VFD control cabinet because of all the add-ons needed for full control systems. I have built 1440GT systems with the WJ200 mounted into the headstock cabinet, as well as ERL and TRL lathes using Yaskawa VFDs. It all depends on the the machine, VFD design and functions.
TE Connectivity TJT50068RJ
