- Jun 12, 2014
- 4,817
Minimum recommended standard enclosure dimensions are 12" wide, 14" tall and 8" deep. Having a clear front window is optional, but also additional cost and not needed. You normally do not need to view the VFD, but I recommend a hinged latched cover that is easily accessible. You need to order a metal back panel to mount the VFD and components. You also need a DIN rail to mount components that might require this mounting system. General recommendations, you may find something cheaper on eBay. A steel cabinet may not need any venting, preferably 12-14" wide, 16" tall and 8" deep should have enough volume. If active venting a fiber box is easier to cut holes in, either a hole saw or jig saw. Back plate material preference is galvanized steel > bare aluminum > painted steel/aluminum.
I have updated some of my recommendations for a 2-3 Hp VFD and have attached them. enclosures run anywhere from $75-150, the lower price range are for ones that come up on eBay, otherwise Automation Direct. If you do not want to use venting you should be fine with a 12 or 14x16x8 metal enclosure. At idle the VFD dissipates around 20W and under full load around 100W, so cooling should not be an issue. The VFD has its own internal fan which will move air through the box. The most important factor is that the VFD should have 3-4" of space above and below the VFD for air movement.
I have outlined the following two options as far as VFD's the first would be the WJ200-015SF in a separate VFD electrical enclosure. An external braking resistor (68 Ohm 500W) is required. I would have a power disconnect switch at the enclosure, and fusing is optional (but recommended in particular if the VFD is not on a dedicated circuit breaker). You need a minimum of a 20A 230VAC service, but 30A is what is recommended. Price wise you are looking at $300 for the WJ200 VFD and probably $300 for the enclosure/components. I would use the metal 16x12x8 or 16x14x8 enclosure with no venting/auxiliary fan. Wiring it up and programming the VFD is not that difficult with the documents posted (or provided by QMT), but these are recommendations and you need to be comfortable with wiring and compliance with all electrical codes. I usually recommend purchasing the WJ200 from QMT so if you have any service issues they can assist you. I have yet to see a WJ200 fail in the past 10 years and with 100's of units, but there is a vary small chance with any electrical device of an early component failure.
If you do not want a separate VFD enclosure, you can purchase a NEMA 4/12 (totally enclosed) VFD and mount it to the outer side of the headstock cabinet along with a braking resistor. The Teco Teco E510-202-H1FN4S-U is a totally sealed VFD with a power disconnect. It would need to be on a dedicated circuit as there is no provision for fusing. It would need an external braking resistor which would be mounted next to it. The VFD runs around $467 and the braking resistor (68 Ohm 500W) is around $60, so a bit easier and simpler than a full enclosure. I have not done an installation with this specific VFD model which is a new series, but I could provide them with the suggested wiring connections and programming parameters, which are different then the WJ200. A full enclosure is a better option if you need DC power supplies, additional breakers, etc.
https://www.wolfautomation.com/ac-drive-indoor-medium-duty-230v-2-hp/
