- Jan 7, 2016
- 3,278
Wow. That is 3x to 4x the amount Dave Florian has in his. I would be interested in hearing about the parts you plan on using.My build is going to be $10-$11k in parts
Ahhhh. That makes more sense now that you are including the mill and all of its accouterments. I already have the mill, which I have been using for a few years now.It is about that much, I almost pooped when I tallied up the spreadsheet for my build. David's website has a bill of materials with links to parts.
Benchtop Mill CNC Conversion
Dr. D-Flo converts a manual benchtop mill, the PM-833TV, for automated machining in his garage. Learn about the mechanical and electrical systems required for this conversion.www.drdflo.com
I followed along, adding what I absolutely needed, and discounting parts/pieces I already have. And skipped the stepper electrical parts, adding instead the AC servo electrical parts.
Starting from scratch my Precision Matthews order was $6k already for the 833TV, its stand, a 4 inch milling vise, R8 collet set, and clamp down set. That includes shipping/tax with liftgate and into shop delivery. After that I needed a $1199 conversion kit. DMM servos (z-axis with brake) total around $1100, and their drivers around $750. Power supplies and cabinet and all the small parts brought it right up there.
He makes sure to state that for this amount you could get a bare-bones Tormach. And recommends paying for a turn-key system, if you want to miss all the fun of what looks to be a 2 or 3 month build. I can only complete this type of project if I follow along with someone who has already done the legwork finding and matching parts, writing it up, and producing videos showing what it's supposed to look like when its finished. Going the DIY route lets me justify some of that dollar amount as "tuition" and "entertainment" expenses.
When I built my Sherline I sourced steppers with dual shaft to continue using the handwheels. I rarely did, but instead used my MPG to work manually.Ahhhh. That makes more sense now that you are including the mill and all of its accouterments. I already have the mill, which I have been using for a few years now.
I did consider going the Tormach route but my understanding is that there is no manual mode. I would like the option of turning a handwheel should I have the need.
I am assuming that the handwheels felt "coggy?" From my understanding the larger the stepper motor the more pronounced the cogging effect. I wonder how that would play out on this mill because the steppers will be considerably larger than on the Sherline. Servos would not have that effect when powered off, is that correct?When I built my Sherline I sourced steppers with dual shaft to continue using the handwheels. I rarely did, but instead used my MPG to work manually.
Yes, the cogging was noticable even on the nema 24 steppers. Also when spinning the handwheel faster, the stepper would generate power and illuminate the lights on the driver even with everything turned off. That could be stopped by disconnecting the stepper leads.I am assuming that the handwheels felt "coggy?" From my understanding the larger the stepper motor the more pronounced the cogging effect. I wonder how that would play out on this mill because the steppers will be considerably larger than on the Sherline. Servos would not have that effect when powered off, is that correct?
Hi Dave,
I bet you'll catch a bunch of us guys trying to do the PM-833T/V models! I am self taught / novice level at CNC. I started by building out a Sherline 5800 CNC ready desktop mill. Now that it's gone, I intend to use the PM-833TV build as both a continuation of the learning, and in support of my other hobbies and interests.
My build is going to be $10-$11k in parts and the CNC conversion kit from Bruce would be $1200 of that amount. My expectations are in-line with "hobby level" accuracy. My preference would be what looks like your standard 940 kit, that has the C7 ballscrews with double nuts set up to avoid backlash, and including the angular contact bearings. I intend to follow David Florians example, including the DMM servo upgrades. I think the X and Y were nema 34 with 1/2 inch shafts and a Z-axis nema 42 with 5/8 inch shaft. A couple hundred bucks either way isn't going to stop me from doing this.
Good to know about the z-axis, that 940 is a heavier machine. I used Stepper Online before, and on this build I want to use the upgrades, keeping in line with the 'more premium' nature of the PM-833VT. But if I don't need that 1300 watt braked motor it would save a chunk, thanks for the practical advise.I read Davids build list and its fine but you can make changes.
The DMM 86N is just fine for all axes. It is a 750 watt servo and most the time you will be milling with 60 watts of power on the X and Y. The only question is the Z and a break. The 86N has been used lots for the PM-940 with no break. If you have medium preload on the AC bearing and snug gibs the head wont drop. The larger 32mm Z screw also has a bit more friction. On my 940 the head does not drop but with the power off and if I hammer on the vise and vibrate the mill it will go down some. I still have a 25mm screw.
I still like some of the closed loop steppers, mostly the Stepper Online drivers are good. 1200 oz for the X and Y and 1600 for the Z.
If you guys want to measure up the parts for me I can make them. We can do it here if you want.
The strange thing here is my best friend from grade school and for many years after was named Bruce Nelson. He had heart problems and died 4 years ago. Still miss hims sometimes....
Thanks
Dave
