    Dismiss Notice
PM-727m New mill has arrived!
Discussion in 'PRECISION-MATTHEWS' started by Sloth2009, Mar 27, 2017.
  1. Sloth2009
    Sloth2009 United States Active Member Active Member
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    Very interesting!
    I am in the process of ordering some Diamont DWH. Their website and ordering process is not very transparent. Surprisingly it is not that expensive in the small quantities we would use on a column mount.
  2. jbolt
    jbolt United States Active User H-M Supporter-Premium
    926
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    My PM-932 does the same thing. I get about .002 to .003 flex if I tug on the head. It has no measurable affect when taking finishing cuts so I don't worry about it.
    wrmiller and tweinke like this.
  3. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    I believe I ordered the same product Stefan Gotteswinter uses in his youtube video on epoxy tramming. In the US, you have to call Devitt Machinery Co. to place an order. Devitt appears to be the only US distributer for Diamant products. Ordering was quick and painless. I will see how the epoxy works when it comes in.
    Devitt Phone: 1 (877) 368-1528
    I ordered:
    50 gram kit of DWH 310 FL: $13.00
    50 gram injector: $2.50
    Greebles likes this.
  4. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    IMG_5068.JPG IMG_5069.JPG IMG_5071.JPG Being a retentive pharmacist, I ordered some teflon washers to fill the gap in the handle knobs. The click clack sound of my uneven rotation irritated me. :distrust:
    fradish, ACHiPo and tweinke like this.
  5. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    IMG_5066.JPG IMG_5067.JPG I also bought a nice little R8 collet organizer
    USMCDOC and darkzero like this.
  6. Ironken
    Ironken United States Active Member Active Member
    168
    43
    City:
    Kansas City
    State:
    Missouri
    -Return to Top-
  7. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    IMG_5078.PNG I tried to mill in the 12mm step in the fixture keys that came with my vise but they proved to be way too hard for my HSS end mills. I waffled on if I would make some stepped vise keys from some 4140 stock or buy some pre-made. I ended up buying some because I didn't feel like trying to harden them. Here is a website you can purchase some stepped vise keys to fit the 12mm slots on the pm-727m.
    https://www.carrlane.com/en-us/product/locators/fixture-keys/step-fixture-keys
  8. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,591
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    T-nuts do not need to be hardened or made from high alloy steel. T-nuts made from mild steel or from mystery metal will work fine in a home shop. You don't want to crank on the fasteners anyway, because you will damage the table or the T-slots. Production T-nuts are hardened, probably to give them better wearing properties and to allow them to take heavier loads without failing, even though that is a mistake. I never gronk down on fasteners going into T-slots. Break out a chunk of cast iron table and you will know why...
    grantj likes this.
  9. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    These look like T-nuts but they are not. They are called stepped vise or fixture keys. They attach to the bottom of a precision vise. They are only T-shaped due to try to match them with the table slots, otherwise they come rectangular. They are also precisely ground and hardened. Kurt sells them for over $30 per pair but not in 12mm. They are precision milled vice keys meant to tram in your vise reasonably accurately to the table slots simply by setting them in the slots.
  10. Bob Korves
    3,591
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    I use shop made keys for that purpose with my BP vise. They are accurately made of 1018 steel to a nice fit in both vise (tight) and table (snug but sliding), and are soft so they do not ding the slots. All the exposed corners are carefully rounded in all directions so they do not scratch and ding the table or the slots. They work great and are essentially free. I have the facilities to harden them, but consider that a bad idea.
    Sloth2009 likes this.
  11. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    That makes sense.
  12. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    IMG_5092.JPG IMG_5093.JPG IMG_5096.JPG IMG_5097.JPG Received the DWH today. It is gonna take some clean up, set up, and other prep work before I feel comfortable moving forward with the epoxy tram. However I thought I would post a few pics of the product. Thanks to Mr. Korves for recommending the epoxy tram video. FYI the cans do have expiration dates.
    Bob Korves and tweinke like this.
  13. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    My z-axis gib is at full adjustment and still needs to move in a little more. The other gibs adjusted as expected. I haven't particularly noticed slop in the z-axis but wanted to tighten it up as much as reasonably possible. I adjusted the screws all the way in and was still able to tap it in a bit farther with a brass rod with out excessive friction on the ways. I had to back the screws off though because the bottom gib screw ran out of thread. I'm thought about cutting a little of the bottom of the gib to give the bottom screw more purchase, but I'm not sure it would get me enough movement. I may have to ask Matt at PM. Is there any known remedy for this besides shimming or remaking the gib?
  14. Bob Korves
    3,591
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Shims.
  15. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,360
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    I have that same R8 rack from Sisan Co that I use for my R8 tooling. I don't use very many R8 collets. I love that rack. Great quality & inexpensive. I ordered directly from Sisan & it showed up the next day. I had no idea they were local to me.
    wrmiller likes this.
  16. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    Yea I like it too. It was priced better than others I saw online also.
  17. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    IMG_5115.JPG I ended up cutting off the part of the gib sticking out. About a 1/2 inch. I was able to get just enough adjustment out of the top screw to get slide reasonably tight and both screws in the right spot.
  18. darkzero
    1,360
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Some people like those vise locating keys, some people don't. I'm part of those who don't, not on my vise or rotary table anyway. I like to slide my vise onto the table (especially if you have a heavy one) & move it around before setting in location. Quick & easy to tram the vise anyway.
    But for my super spacer & tailstock I do use them. I don't rely on them for tram but rather for a general index for one table slot to help get the tailstock in line quicker when I need it.
    I did have to mill a step in the locating keys for my super spacer to fit my table. Carbide end mill did the job.
  19. TheGov
    TheGov United States Iron Registered Member
    13
    3
    City:
    Twin
    State:
    Idaho
    -Return to Top-
    After a few weeks making chips, last night I noticed that the 'Y' table has developed some slop in the y direction. I snugged down the backlash adjustment, but that didn't effect the slop. The play was the same.
    Any suggestion on where to look for this new play?
  20. darkzero
    1,360
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Adjust the gib.
  21. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    I just adjusted mine... I pulled out both gib screws and lightly tapped the gib in farther from the front with a little piece of brass and hammer until the slide stiffened up. Replaced the screws and adjusted them until I got a reasonable balance between friction and tightness. Both screws should be tight when finished. You can adjust with just the screws but I found it hard to feel how tight the gib was. You can also use the table movement to slide gib in and out out if the screws are loosened up. Essentially you need to tighten the front screw and loosen the back screw to move the gib in and tighten the Y axis up.
  22. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    For the PM-727m, The Z-xis gib needs to move down to tighten. The X axis gib needs to move left to tighten. The Y axis gib needs to move towards the back of the machine to tighten. The gib is essentially just a wedge you drive inbetween the ways to take up non linear movement.
  23. TheGov
    13
    3
    City:
    Twin
    State:
    Idaho
    -Return to Top-
    Thanks for the info on adjusting the gibs...Found out what the real problem was though, the bolts that hold the lead screw nut to the saddle were holding on by tess than a thread.
  24. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    Glad you found the issue. Did you have to take both tables off to get to that?
  25. TheGov
    13
    3
    City:
    Twin
    State:
    Idaho
    -Return to Top-
    Nope...just the X axis, (turns out I said Y when I really ment X...proof not to post while at work)
  26. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    Buggy Chief and fradish like this.
  27. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    IMG_5141.JPG Has anyone used these Kodiak carbides? I've never bought $$$ end mills before so I hope they are worth it. If they turn out good I will probably pick up the square 4-flute set also.
  28. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    IMG_5144.JPG Quick and dirty end mill organizer. The wood is an ash wheel barrow handle you can by at any home improvement store or $12 or so. You could get a lot of these out of a handle. I had some left over from another project. Makes a pretty decent end mill and bit organizer.
  29. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    IMG_5151.JPG IMG_5152.JPG IMG_5153.JPG IMG_5154.JPG Newbie aluminum practice. I cut the narrow outside surfaces with a 3 insert inexible face mill. After failing to grind a HSS bit correctly, I used a carbide bit in a fly cutter with a right handed spin to cut the wide outside surfaces. I hogged out most of the center with a 3/4" corncob rougher. Then cleaned it up and made the cross with a 3/8" 2 flute HSS Pend mill. I then chamfered the top and bottem edges with a 3/8" ball nose carbide end mill.
    tweinke likes this.
  30. Sloth2009
    100
    33
    City:
    Billings
    State:
    Montana
    -Return to Top-
    I found a better fix to the handle clicking. The screw shaft that the handle spins on protrudes slightly out the back. This shoulder was catching the teflon washers and tearing them up. I wanted something to just barely fit over the shoulder and still be fairly low friction. I measured the shoulder and ordered some copper crush washers from Amazon. When I installed them, I hit the screw shoulder lightly with a file so when you tighten the screw down the pressure forces the washer onto the handle shaft. Along with some blue thread locker I finally got the handles how I want them and the copper washers should last luch longer.
    Copper crush washer:
    https://www.amazon.com/dp/B01MTZWSSO/ref=cm_cr_ryp_prd_ttl_sol_0
    tweinke likes this.
Share This Page
