- Apr 23, 2018
- 6,607
This thread conjures images of St. Vincent of Saragossa, except instead of a millstone, a chuck.
I did not want to attach anything to the lathe itself because of the stress, torque that would result. There is a youtuber who has one on his Monarch. The PM-1640TL is a huge machine, but it is no a Monarch.Holy moly these 10” chucks are beasts.
I have read some of the threads here about quick change tool post mounted Skyhooks on lathes, and it sounds like while they look intuitively scary, they are pretty safe.
That said, does anyone have experience with mounting one on a PM-1640TL or similar?
I just milled the blank base on my inexpensive CXA quick change tool post, and it’s not a ton of steel that holds it to the cross slide. Curious if anyone has any first hand experience with mounting a Skyhook to it.
I want a skyhook. I'm chicken when it comes to heavy things that can roll, especially onto my toes.What may seem insanely heavy to our muscles is virtually nothing to the capabilities of an industrially rated machine tool, and the skyhook is a well engineered and quite safe, I have never had a problem with the two that I have owned, the load brake is quite controllable under load. I also have a tram rail, actually a barn door track above mu lathe and mill with a HF electric winch for chuck changing and mill accessories such as the dividing head, etc, but the skyhook also swings to retrieve heavy objects off the floor onto the lathe or mill that he electric hoist cannot reach.
Another detail, I drilled and tapped all my chucks for an eyebolt, so no getting away from the hook.I want a skyhook. I'm chicken when it comes to heavy things that can roll, especially onto my toes.
I was planning to put a pipe through the chuck; then have a riser such that I can hook on to it. Sort of a large upside down question mark. I have seen others do something like that.Another detail, I drilled and tapped all my chucks for an eyebolt, so no getting away from the hook.
I did that for the dividing head, but like the eye bolts for the chucks better.I was planning to put a pipe through the chuck; then have a riser such that I can hook on to it. Sort of a large upside down question mark. I have seen others do something like that.
where did you drill the hole? what thread? what about balance?I did that for the dividing head, but like the eye bolts for the chucks better.
Mostly the tapped holes are about the center of the body of the chuck or a bit to there left to compensate for the back plate's weight, most of them are 1/2 -13, although my 10" Buck Chuck came tapped for 5/8 - 11.where did you drill the hole? what thread? what about balance?
