- Nov 16, 2012
- 5,596
Hint: When you get around to it (and do take your time and enjoy the journey) first do the Rollie method and then fine-tune with the two collar method. The results will knock your socks off.
When doing the two collar method, try to find a piece of aluminum round stock at least 2-3" diameter and no longer than 9-10 inches or so.
Once that is dialed in, go ahead and make a two collar long bar (about 1/2" the length of the bed) and get the tailstock centered.
I check mine once in a while just the same way you tram a mill -all part of normal maintenance and operation.
I've got a bunch of threads here on how to fine-tune the D1-4 mounts and static balance your chucks. In no time, it will be a fine-tuned machine.
If you just want to mess around and cut some metal before doing all the fine tuning, go ahead, it won't hurt anything.
You'll love it. And Oh, try not to sleep too many nights in the shop...
Ray
Ray
