Is that a screw on chuck? If not mount it in your tool post.
I do it this way all the time on my 7x14 Mini-Lathe using P style cutoff blades mounted on my home made quick change turret. I can cut slices from 2" dia. steel bar. Email me at jayman03062@gmail.com for pics. TYPE "CUTOFF" ON THE SUBJECT LINE TO AVOID CONSIGNMENT TO MY SPAM BLACK HOLE.There are numerous videos on tricks for using parting tools but I found one that seems too simple and obvious not to be used universally.
His graphic makes it seem very simple but I don't quite see how it is not dependent upon the position above or below center.
I tried it on a piece of PVC in my mini and it works as advertised. To me, the most obvious advantage is the way it pushes the chips out the bottom.
Doing it the normal way, I have to stop frequently to remove the tangled mess of chip, including using a scissors to cut it loose.
I am interested in some opinions of this....
js
I was saying if it's not a screw on chuck just mount the blade upside down in the tool post. Exact same affect as a rear mounted post.
Glad it's working better. I wanted to tell you to strongly consider using a ledge under the tool holder. It anchors the tool solidly and makes any off-axis movement impossible.
