- Jul 20, 2012
- 1,241
An interesting challenge. How 'bout:
Run your stock thru a collet to a fixed stop position.
Have a custom made tapered tenon cutter (like a pencil sharpener) mounted in the tailstock.
Kinda like this. From: http://www.fine-tools.com/zapfenschneider.htm
This tapered tenon cutter would be advanced onto the stock, cutting the taper, and its inherent design (inner taper) would stabilize the shaft during the cut. The very front, non-cutting short section of the cutter's entry hole would have an ID slightly larger than your stock rod. Once the taper cut is made, the tool is left in this position so that the non-cutting entry hole will act as a steady rest on the end of your workpiece, stopping just shy of the first groove.
Then cut the grooves with the formtool. If stock is consistantly fed to a fixed stop position, the carriage can be locked down, for consistent/repeatable groove/formtool cuts.
Of course, use plenty of bacon grease during all this.
Mmmmmmmm, bacon...
I recall one of the Tubal Cain videos shows him using a cutter like that for rounding ends. Not sure which one though.
